12thgenusa
Apr 24, 2015Explorer
bguy wrote:
The best is to break both connections. If that's not an option break the pos side. If you break the neg at the battery you leave the whole unit with potential should you inadvertently create a ground connection.
No. It's not possible to inadvertently create a ground connection as nothing is a ground unless you create a path directly at the neg batt terminal. If you use a knife switch type (with lots of bare metal) the only place to safely use it is on the ground cable.
44,056 PostsLatest Activity: Jan 12, 2020
