sd75macExplorerApr 24, 2015Battery DisconnectWhat's the opinions on which battery terminal to connect a disconnect switch, positive or negative? Thanks,
hawkeye-08Explorer IIIApr 24, 2015What if you have 4WD, doesn't that change whether you put the disconnect in the positive or negative?
Related ContentBattery disconnectBattery Disconnect ConfusionRemote battery disconnectHouse Battery Disconnect Not WorkingDisconnect batteries?
