dmax ed wrote:
Thanks for the help guys, I just looked under truck 7 pin wires go into a terminal, not sure how to wire in a solenoid, Since I have a 3ft deck on the back of camper unplugging every time could get to be a pain. The wire plugs into the front of the camper runs down along the insider of the bed and comes out at tailgate and plugs into the bumper. At the tailgate it can be reached easy, At this point is there any inline systems that can added to disconnect what wire that needs to be, or do they all have to be disconnected
Just the charge line needs disconnected.
Historically, GM uses a red with black tracer wire under the hood that is NOT connected to the auxiliary post on the underhood electrical center. You can disconnect that line and then route it to a solenoid, then run a new wire from the other side of solenoid to where the original wire was connected.
BUT, I can't say for sure that the underhood stuff is the same on the 2015s, because I believe GM finally implemented the CANBUS system on the GMT1000 platform. (it's a network bus communication system that controls most electrical)
