mgann
Mar 28, 2019Explorer
Battery Draw down
Just replaced old with new group 31 rv battery. Nothing is switched on and LP monitor disconnected but something still drains my battery by 1 volt per day. Any help in resolving this is appreciated in...
mgann wrote:
ok, my unit is a Magnetek power converter model 6345, as far as I know it is the original to the TT which is a 1995 Mallard. I checked the fuses for arc and found none. Did not check with ohm meter but called my local mobile RV tech which is aware my my problems and said my problem was a bad converter and he would replace the bottom of the converter for approx $200.00 plus labor and service call for a total of $300 to 350.00. This sound ok to to all of you?
