egarant wrote:
I will check and see if fuse #30 does indeed kill the 12 volt feed to the 7 pin receptacle, that would be terrific if it does. In the manual it is referred to as the Trailer Tow Receptacle, hopefully it just kills the 12 volt feed and not the other functions.
Thanks for that tip, should have thought of it earlier. That is why i LOVE this forum!
I finally got around to pulling the fuse today then testing the lights visually and the plug with my volt meter.
Results: Pulling fuse #30 just kills the 12 volt hot lead to the 7 pin receptacle, everything else works as designed. So now I keep that fuse in a clear 35mm film canister in my glove box and will pop it in when I want.
Hurray!
