jmiller12
Aug 12, 2018Explorer
Battery Life?
Newbie here. I've never boon-docked before, and was wondering how long I can have the lights on in my TT before the battery gets to a critical level (from what I've read below half way charged is bad...
For you folks that know about this stuff, what is the lowest that you should ever let a battery be discharged to? Before permanent severe damage is done?That differs by type of battery and construction. Typically, a dealer will equip a trailer with an inexpensive 12V marine-starting hybrid, many of them are BCI GRP24. This type of battery will last longer if never drawn down below 50%. A 12V FLA auto battery will fare even worse. Draw it down below 50% a few times and it will be very limited in capacity or toast. 12V AGM batteries fare better from high draw but the 50% rule of thumb is best. Two 6V in series connection will fare the best of high draw down because the cells are constructed better than typical 12V batteries.
