ADK_Camper
5 years agoExplorer
Battery Monitor Install
I installed a battery monitor in our camper. It cost less than $20.00, and gives far more information than the OEM battery monitor. Among its various features is an alarm to indicate when the battery voltage drops below a set level.
The monitor is mounted on an interior wall that is near the converter so I could access the necessary connections. It must be connected to the battery's positive terminal, and a shunt (included with the monitor) installed in series with the wire directly connected to the battery's negative terminal. The other end of the shunt also connects to the monitor. The shunt enables the it to determine the total current being supplied by the battery. I used telephone wire (remember when the phone was hardwired and bolted to the wall?) to connect the display. It requires a total of 4 light weight wires. Telephone wire is perfect because it conveniently consists of 4 color coded wires in a single cable and it only costs 19 cents a foot!
The monitor displays the instantaneous battery voltage and current (amps). Form these values it calculates the instantaneous power (watts) and calculates the cumulative energy (watt-hours) used since the monitor was last reset. It has a switchable backlite to illuminate the display if needed. The picture was taken with everything OFF. The .2 amps therefore is the total of the parasitic loads (Propane/CO detector and radio).
