Kayteg1
Feb 23, 2016Explorer II
Check the voltage on the plug per pictures above.
The 7-pins are high maintenance items and often need cleaning or adjustment.
If you have no charging power on the truck side - check the fuse.
30 amp can be blown when you connect deeply discharged battery .
On my F250 I had PO putting automatic breaker for the circuit.
44,056 PostsLatest Activity: Nov 19, 2013
