Driftwood132
Feb 23, 2016Explorer
Under the hood on drivers side is a fuse block under a plastic cover that is where a 30 amp fuse for the charging circut is. The manual will tell about it or the plastic lid will show the location of it. Also the engine has to be on before the relay will engage the charging circut .
When I first bought my truck it wouldn't charge ,F250 it didn't charge the house battery after a little reading the manual I found the problem , no fuse . like other reply check the plugs and wires under the truck there is a couple of connections between the front to the back . if you have a meter or a simple light you can find the problem.
44,056 PostsLatest Activity: Jan 12, 2020
