westend
Oct 16, 2015Explorer
stigle wrote:
I have a travel trailer. The battery is not holding the charge and keeps dropping.while camping. I am hooked up to 30 amp. I purchased a new deep cycle battery and am having the same problem. What charges the battery when it is not hooked up to a vehicle? I'm not sure what i should be checking but would appreciat any advice. Thanks!
When disconnected from vehicle and connected to a campground pedestal, the converter charges the battery. To check operation of the converter, measure voltage at the battery terminals. It should be above 13 V. Is it possible you miswired the cables to the battery, even for an instant? If so, the reverse polarity fuses on the converter may have blown. There is also a circuit breaker or fuse between the battery and the 12V distribution panel, typically located on the tongue or frame.
Good luck.
