I agree with keeping it on auto, in case of power failure, the refrigerator will switch over to the propane, and keep everything cold.
How much of a in-convenience is it to refill a propane tank, and what time will that take, is it really worth the time - even if electric is say $2 a month more expensive than running on propane?
Now how to figure that cost, the same goes for the water heater, and electric space heating.
To get 80,000 Btu's of heat from 1 gallon of propane, run the furnace a couple of hours, burn that gallon of propane (or the refrigerator for about 40 hours). Or you can use a electric heater and burn 22 KW of electricity to get 80,000 Btu's of heat. What is more expensive? If you are paying the 9 cents per KW like in Portland Oregon, home of much hydropower, then it will cost $1.98 for electric. Propane is a bit more expensive now, around $3 per gallon.
Your local area might vary. Say you are paying 15 cents per KW, like southern California. Then 22 KW is about $3.30. So if your propane supplier is only $3.00 per gallon, buying propane is less expensive. But in most parts of the country, electric will be less.
Ammonia refrigerators are not energy efficient. However they are the only kind that can run from a propane flame, and as such can be run while boondocking (in a practical manner). To run a electric refrigerator while dry camping, you would need to run the generator a lot, need to carry more than 100 extra pounds of batteries, and perhaps 400 or so watts of solar panels to lessen the time spent running the generator.
The ammonia refrigerator will run many more hours per day and consume more energy than a small bar type refrigerator. It can run 5 - 12 hours per day using 300 watts per hour with outside temps in the 50 - 80F range (night and day). A bar refrigerator with tiny freezer section might use 50 - 75 watts and run 3-4 hours to do the same job with only a total of 350 watts per day.
Fred.
