Wishbone51
May 26, 2015Explorer
Use a meter to check if voltage goes up when connected to shore power. I had a fuse go out between the battery and the power converter that was located in a panel on the underside that I had never had seen this before. Battery wasn't charging.
The battery powered the slide and the jack just fine, as these had separate fused connections, but the interior lights didn't work unless on shore power until I replaced that fuse.
44,056 PostsLatest Activity: Nov 19, 2013
