time2roll
May 26, 2015Nomad
Check the battery voltage first. Check on the battery terminals, then check in the 12v fuse panel inside the RV.
Post the results but I think you need a new converter.
A 5+ amp portable battery charger from the local WalMart or autoparts store will get you back in 12 volts until you can figure out the converter. Just put it direct on the battery and plug in. Nothing to disconnect.
44,056 PostsLatest Activity: Jan 19, 2026
