BAMA_57ExplorerMar 14, 2014Battery QuestionMy battery on my Travel trailer shows over 12 volts but the lights inside the trailer are very dim. Dose my battery need replacing?
azrvingExplorerMar 14, 2014Have you checked the water/electrolyte level? It should always be over the plates. As said above, if you are seeing that voltage while plugged in it may not be charging. It should be reading 13.2 or so when charging.
Related ContentBattery QuestionHouse battery drainBattery & electrical questionsLithium Battery QuestionBattery questions
