lawrosa wrote:
For over $500 bucks for a 8A8D 150 lbs AGM @ 245 AH is ridiculous IMO..
Get two 6V from wally world or the cost saving centers and get the same amp hours..
The first GC2 6 volt here in this duracell link is 230 aH and are $89 bucks at sams club for example..
Weight may be similar but 1/3 the price...
At least you can move these individually and not need two guys to move them. And they fit in most battery boxes as they are only a little taller then a grp 24...
GC2 duracell
First, the price you quoted is typical MSRP, but you can get them for $269 if you look around.
Second, that GC you linked to is the first one I've seen with that many AHs. So thank you, because that just became a big contender. It would make more sense at that point. Most I've seen were between 190 and 205. Wonder why so much variation? But no matter, if it's 255, it's better. Speaking of the next larger one than you referenced. But it's not AGM. Am I overly concerned with that?
For other posters, yes, I have already figured how I would mount the 8 series. And yes, I'd like to get solar. Only issue I have with solar is my typical boondocking place is surrounded by trees. So it would work, just not as efficiently as it could.
Thank you all for responding.
One final question. And this would apply to either option really. Am I correct that 12v is 12v and the big difference would be how long it would take to charge? In other words, a converter or charger just sees that it's 12vs, and when wired in parallel, it just sees one bigger 12v. Or in the case of the 8 series, one battery, but simply bigger? Am I correct that if a system will charge 12vs, it'll charge any 12v system of battery?
