drumming102's avatar
drumming102
Battery Question
I have 2 diffrent batteries on my trailer (Pictures of each in below link) 1 came from the dealer (the interstate) the other I believe is an older Cell Site backup deep cycle. It's sealed but I know nothing more about it than that. I serviced the Interstate today and topped off the cells but is there an issue running these 2 in parallel on the trailer?
How many AH is the Interstate and how many AH is the other (Looks like 90AH to me)?
My plan is to try to hold off on buying 2 GC2 batteries till next year if I can but the 1 interstate wasn't cutting the mustard by it's self. They do ok together but thought it best to double check with you guys to make sure it was ok.
http://imgur.com/a/fz8lg
    Holy cow! You really have a poor situation there. You are mixing battery types.... The green battery is probably an Interstate battery ... a flooded wet cell type, and the Marathon is an AGM battery ... very different types. It is bad enough to connect an old and a new battery together but you are mixing totally different types. One of the problems with this is the lesser and weaker of the two batteries will simply pull the other battery down to whatever level it is. I don't want to spend the time outlining why this is bad practice.
    Still, you might be able to make it through 2016 with these if you don't use them much... I wouldn't want to bet much money on it. Good luck.
