How much electricity you use is very much a function of how you live and work. You don’t have to use a microwave or a tv or a laptop computer or an electric coffee maker or popcorn popper or hair drier or more than one light or a heater, fan, etc. But the more of them you want, the more power you will use. Captain Obvious, I know.
But you asked about batteries, so let me explain. Your pair of inexpensive lead acid batteries afford you around 300-500 charge discharge cycles provided you never discharge them more than 50%. A typical lithium iron phosphate battery will go around 10 times as many cycles at 80% discharge. That $125 flooded cell battery of which you wrote has only about 80 amp hours capacity, and the pair will allow you to draw only 80 AH before needing a recharge. A single 100 AH LiFePO4 costing that $1000 will also easily give you 80 AH. To cover the same total lifespan of the lithium battery using the batteries you have will cost at least $2500. I say at least because they will not be cheaper in the future when you will be buying the second through tenth pair. That is a big reason people are buying lithium. The other is weight. Those two batteries you have probably weigh around 150 lbs. The lithium battery tops the scales in the 20-30 lb range.
So if you were someone who found themselves burning through enough electricity to warrant a half dozen batteries, the advantage in long term cost and weight would be significant.
