for the original poster, they are buying 4 batterys because for the longest time all comercial builders offered was 100AH batteries. which for the average person with a older camper is enough. but new camper have slides, power awnings microwaves, ac, tv sterio and on and on where 100ah can be used up pretty quick, and you can usaly fit 4 in some of the larger battery compartments or genny compartments. the other way you could do it is to build your own and for a few inches bigger in a two of the three dimentions you can get up to 300ah in one battery.
pianotuna wrote:
adamis,
SiO2 share many of the attributes of LiFePo4. The difference is weight--where Li are lighter, and cold weather, where SiO2 can be charged and drawn from at -40. SiO2 do not need a a bms. They can be continuous discharged at more than double the rate recommended for Li, which makes SiO2 wonderful for large inverter use.
your forgetting a few things again also your previous post using the term cool weather realy. haha
so yes weight is a huge dufference, 1/3 to 1/4 the weight, cold weather meh for the 0.01% of people on here that extream camping might be a concern, and can easily be mitagated. even for you if you would move your house batteries inside the heated space.
I dont know why people are hung up on a BMS, it isn't something you need to buy extra, it is part of the battery.
dischage rate is good on SIO2 but you cant do it for very long. people tend to get hung up on this also, but it is a floating target. generaly the discharge rate is 1C, or a arbatrary number a manufactur sets because they want to save money and use a smaller BMS in there build. so at 1C on a 100AH battery the rate is 100amps for one hour where a 100AH SIO2 can only do it for 30 min if you want to get the most life out of them. also the thing I dont like about using the discharge rate is , who is going to put one 100 AH battery in a unit when they are planing on usung draws over 100 amps? as the original poster stated people are putting 4 batteries in so four 100 amp Li will give you a 400amp draw ability. or if battle born would get with it and start making things afordable and building what some other companies are you can get a 300AH 12v battery that isnt much bigger than the present 100AH offerings and they are 300amp discharge out of the box.
Li prices have droped to the point where SIO2 are actualy more expensive now also. and the other disadvantage to SIO2 which is also the reason people use them at -30 they only have 60% of the original capacity, which is way better than agm or LA ... so if you have a 100AH SIO2 qt -30 it only has a capacity of 60AH of which only 30AH are usable if you want the long life out of them. yes they can handle some totaly discharges but it still isnt recomended to go past 50% for max life on them. with Li , camping at that tempature takes some tempature managment planing so the battery will have 100% of the capacity availble.
there is downsides and upsides to both and I think SIO2 are one of the only two real choices and I think they are more for a specialized situation where you can't move your batteries and you don't care about weight. seeing this is in the truck camper forum I would say there is a good chance everyone who has a truck camper has weight of things on there mind as most of the campers now days are already over the capacity of most trucks before you even start. take mine for example, it is old and light, but after I squeezed two GC2 batteries into it to get a whopping 210AH capacity which I can only use 105AH out of. My weight when up by 132Lbs and I lost a outside storage compartment, yes I have a older unit that only had a space for a single battery and was to small to do anything with. when My LiFePo4 cells arive (sorry I can't aford to buy battle born and it dosent make sence when I can already put six 6V batteries togeather to have a 12V output. ) so I am building my own. there is a small useless storage area inside that amazingly is just large enough to get two home made batteries in,so I can expand if I put a microwave in later or what ever... right now I will just be putting a singel 300AH battery in which will give me 3X the capacity of what I have now, free up that whole outside storage again and reduce my camper weight by 90Lbs. its even a more dramatic change in the 5th wheel, Ill free up 200lbs of direct hitch weight, free up 8 cubic feet of storage in the front hatch and take the capacity from 230 usable AH to 900 usable AH.
Steve
