GA1dadExplorerDec 11, 2016Battery TendersKeep in mind I'm a noob to the diesel world,,,,, So twice now the batteries have run down on my Duramax from lack of use. I'm starting to look for an inexpensive tender that I can mount to the vehi...Show More
Chuck_thehammerExplorerDec 12, 2016answer is not so easy..the older the battery . the faster it discharges.I avoid the cheaper tender types.. Deltron Battery Tender was top. others are catching up.1.5 amp with 2 batteries.. adding a single 2 amp diode will stop back draw.over 3 weeks I can see a slow start. but NOT a No start.. if it continues have truck checked.. do you have add-on electronic devices in truck, they may not be turning off.
Related ContentBattery tender & storageAGM batteries & solar battery tenderBattery TenderBattery TendersBattery Tender
