westend
Jan 06, 2018Explorer
RRZNagas wrote:Good deal, problem solved. :)
I’m not an electrician or rv battery specialist, so when the Jayco comes with two batteries, I assume that it’s for a reason. So I got one to replace the stolen one.
If you have two GC2 6V golf cart batteries, you might be able to run your CPAP machine for a few nights, away from a pedestal. That may broaden your camping experiences.
There have been a few discussions in the "Tech Issues" section of this Forum about CPAP operation. Many solutions to running a CPAP from either 120V or 12V.
Having two batteries is a good operational scheme. The two batteries will cycle down less than a single, therefore, longevity should be increased. It's always better to start with two alike batteries than a combination of used and new but circumstances sometimes come into play. I'd suggest to really charge the single battery you have. Do an equalization charge on it (16V until boiling electrolyte, stop). Finally, if you have a hydrometer or the rig is in a shop, dip all the cells and accurately assess the battery's health.
Good luck with the battery and theft situation.
