rjstractor
Sep 27, 2013Nomad
Lessmore wrote:
In fact Ford uses...I believe...a version of the Cummins B series 6 cylinder diesel in their largest truck, the medium duty F 650.
The Cummins B series 6 cylinder diesel is the same family of diesels, just another version that is used in the Dodge pickup.
I've often wondered why Ford never used a version of their own power stroke diesel in their medium duty F 650.
GM, before they shut down their medium duty line of trucks, the 4500/5500 series.... used a version of the Duramax diesel, which of course is also used in the GM pickup line.
Good questions, since until recently the Powerstroke was International-sourced, and IHC used those engines in trucks comparable in size to the F650/750, as well as school bus applications.
As far as GM, the 4500/5500 were in the same GVWR class as the Ford F450/550, which did use the pickup truck drivetrains. The Kodiak 6500/7500 did not use the V8 Duramax, although some versions did use the 8.1 gas engine.
44,066 PostsLatest Activity: May 16, 2026
