Hannibal
Oct 01, 2013Explorer
The Mad Norsky wrote:Hannibal wrote:
I don't care about who's fastest up the grade either. Obviously! However, what the test did show is that all three ran balls out towing 20k lbs up the grade with no failures or hiccups. That is the criteria I'm interested in. All three proved very capable.
BUT, (a big one :B ) here's my point. I personally would hope that I never end up with any of those trucks used in the commercial.
They've been abused, albeit possibly short term, but abused nevertheless.
Its always been mentioned on here, when giving advice for folks doing some towing over, say I-70 west of Denver, to NOT try and be fastest up the hill because one does NOT want their EGT's to go too high, or over 1200 degrees I believe.
Can one imagine what the EGT's were on those three vehicles???? Turbo boosting to the max and running flat out as hard as they could go?????
They had to be getting very, I mean VERY very warm.
EGT = exhaust gas temperature.
Any truck that can't pull a grade WOT without overheating anything needs to go back to the drawing board. Every truck I've owned over the past 25 years has seen extended WOT without any ill affects. Way back in '84, my Isuzu P'up diesel saw high rpm WOT from Virginia to Sarasota towing a box U-Haul trailer. Not even a hint of trouble. Your fear of using a truck's full potential isn't an engine weakness. Those trucks are fine. If not, they're flawed.
44,066 PostsLatest Activity: Apr 10, 2026
