Executive45
Sep 24, 2015Explorer III
Couple of things come to mind. First, what made you 'suspect' something was amiss when you took your rig to the dealer the first time..:h
("While in, I thought I would get them to pull the drums off and see what things look like.")
Why do you suspect a bearing failure?.:h Could you have a brake shoe that's hanging? That would cause the higher temp. Finally, you said your second check showed the wheel at "30F higher". Higher than what? the other wheels or higher than your previous check?...thanks..Dennis
44,026 PostsLatest Activity: Feb 22, 2025
