93Cobra2771
Sep 25, 2015Explorer
project_tenkiller wrote:
Yes id check it there .when a bearing fails,the wheel could fall off, had it happen on a hay mower trailer yesterday.if its the bearing, easiest way to see if a bearing is worn in most cases, is to jack it up, grab top and bottom of the tire,then wiggle back and forth. Excess play usually means a bearing is going.physical and visual are always the best way to check though. But from whAt it sounds like i would guess pad and drum are rubbing a bit.
This. Grab sides and give a good shake and see if it feels loose. While up it would have been great time to remove wheel and do a visual inspection of bearings.
44,026 PostsLatest Activity: Feb 22, 2025
