Hey guys, I have a double axle 26 foot camper. Today I removed cleaned and repacked the bearings (on side of my camper). I didn't put a ton of grease in and around everything, but I was caref...
Community Alumni
Jul 11, 2017
Approved
Yeah I think the OP is missing the point. If you hand packed the bearings then there's no need to use the Zerk. The Zerk just fills the void in the hub in an attempt to force new grease into the bearings. You don't need to do this since you already forced new grease into the bearings by hand. The bearings got all of the grease that they needed when you packed it by hand. If you packed the bearing, grease oozed out of the rollers on the other side, and added some grease to the outside then you're good to go.
