subcamper's avatar
subcamper
Explorer II
Apr 30, 2013
Bearing Seals
I'm about to repack the bearings on our Rockwood 8318SS and I have a question.
In the past I have just bought new seals locally and they were
"matched up" by size at the store.
The seals are quite a bit cheaper at etrailer.com and they have standard lip seals and double-lip seals. I'm not sure which I have now on the trailer. Their web site says double-lip seals are better for boat trailers and help to keep water out better. Is it OK to use double-lip seals on my Rockwood? They only cost a little more money an if they are better I will get them. Are there any disadvantages to the double-lip seals? Will they seal properly on axle that didn't come with double-lip seals?
Thanks
Steve
  • Thanks, everyone for the fast responses.
    I am now going to order the double-lip seals from etrailer.
    Steve
  • The double-lipped seals are used on the E-Z Lube axles to help keep grease out of the brake drum.
  • Either one will work. The doudle-lip that is used on boat trailers are designed to keep lake water from being sucked into the bearings when submerged.
  • Steve, They will work fine. Either one will do.
    Brian
