egarant
Oct 18, 2023Nomad
Bed Mat Base
I want to start off first by thanking FORD for making their bed sides/rails higher than most, certainly higher than my pervious RAM, necessitating me raising the camper in the bed of the truck.
I did search and read PAGES of info on different methods…I think I have settled on the plywood, high compression foam, bed mat solution.
My question or observation is, using the above method, I didn’t see a recommendation that a sheet of plywood be first put on the truck bed floor as it is not completely flat, before putting the foam board down.
So plywood/foam board/plywood/bed mat…..a foam board sandwich screwed together, that seems more logical then letting the bottom of the foam board get destroyed on the unevenness of the truck bed.
Or is making a 2x4 frame with the foam in the middle with the bed mat on top the better way to go?
What do you think?
What do you think?
