donn0128 wrote:
Hondavalk wrote:
Golfcart wrote:
I look at dry weight because i know im going to add a thousand pounds of random to it when i travel. so 6500lbs or so is my ideal maximum weight i want to tow due to the capabilities of my truck
Same here. Seems easy to do the math :B
So what happens when you actually load 1050 pounds?
Real world your probbly grossly inaccurate with your 1000 pound guess.
And, for you GVWR naysayers all I can tell you is next trip out drive across a set of scales. You just might be in for a real surprise.
BTW, my fiver has a GVWR of 13,750 and I generally scale at 13,500 pounds. And we do not load heavy.
The OP has been camping for years. He knows how much he adds, Just like I do. Weight my last TT loaded to camp. I actually added only 650lb to the dry weight. Put the same stuff minus a little in this one. Experience will win out. And like I said. The GVWR is a totally useless number. UNLESS it is very close to the dry weight. Yellow sticker dry will get you in the ballpark
