Tom_Anderson
Jun 03, 2017Explorer
ticki2 wrote:cewillis wrote:NRALIFR wrote:
Easy fix for the fill hole: I suggest the use of a "Digitus Secundus Manus" (index finger) to check the oil level. The bung looks plenty big enough.
We think alike, friend.
Yep , a little common sense goes a long way . It does beg the question , since it is probably an axle specific cover , why the fill plugs isn't at the correct level to begin with . I am sure it is not a cheap cover .
The plug is higher than normal because it's very common in the off-road world to rotate the axle housing for a better pinion angle and more clearance. It's much easier to use a finger to check the level than it is to park the truck facing downhill to get enough oil in it.
I have those covers on both ends of my rock crawling rig and they have proven to be pretty much indestructible.
