I would definitely look into a more heavy duty hitch. I would load up the trailer and run it across a scale to see exactly how heavy it is. Chances are you're already at or over capacity of your current hitch since it appears to be slightly bent. A safe bet would be to calculate your tongue weight at GVWR of the trailer and purchase a hitch that has at least that capacity. This would be the heaviest tongue weight the hitch would ever carry. Look at what's stamped on the coupler, but chances are you should be using a 2 5/16 ball.
