Just went out to the trailer and you'd think they'd stamp the info other then up underneath the coupler area.
It does need a "2 5/16 ball, Not to Exceed 14K gross, tongue weight not to exceed 2100lbs."
The hitch is an EZ lift from C.W.
The GVWR of the Trailer is 7000lbs. Unloaded it is 5425 and last weekend when heading out, w/ our normal gear packed, the scale read 5950.
Picked up a new 2 5/16 ball, with a 1/14 shank diamter, 2 3/4 shank length, with a 12K capacity.
Now looking at CURT Replacement MV Round Bar Weight Distribution Head #17075 and CURT Replacement MV Round Bar Weight Distribution Spring Bar #17074. W/ both rated to 14K trailer wgt. and 1400lb tongue weight.
And again thank you all so much!
