RobertRyan
Apr 26, 2013Explorer
Another manufacturer Spinifex and a 24ft Van.
More details on the added extras on the Caravan.
Specifications
Model: Spinifex Outback Explorer Off-Road
Length: 24 ft Ext. (22" internal)
Colour: Champagne Powder Coating/Maroon & Black Decals
Year : 2010 (October)
Chassis Laminated 2X4" (50mmX 200mm) hot dipped galvanised.
Frame: Custom riveted aluminium (No chance of wood rot here)
Tare: 2840Kg (The empty weight)
ATM: 4200Kg (Total allowable weight of the van and contents. Note: Landcruiser
towing maximum 3500Kg)
Ball Wt: 280KG (Down force exerted on tow ball)
Reg To: 10/2011
Brakes: 12" Electric over hydraulic disc brakes on all four wheels
Wheels: 17 inch, 5-stud Landcruiser
Water: 1X90 litre dedicated drinking plus 3X90 litre shower etc.
Tyres: 275/75R17 Cooper Discover A/T on 17 inch, 5 stud alloy wheels.
Susp: Vehicle Components Independent Airbag with shock absorbers.
Tow Hitch: Vehicle Components DO45 (4500Kg capacity.)
Beds: Custom Made Queen (6'10" X5'1")
Fridge: 230 litre, 2 door, Vitrifrigo, 12 volt compressor.
Solar: Three X Kyocera 130 Watt solar panels (Capable of 32 Amp
charge in full sun)
Batteries: Three X 120Amp/hr, Absorbed Glass Matt Sealed, 12 volt.
Charger: Fully automatic Phoenix 1600 watt/70amp charger. (70amp
charger allows for rapid recharging of batteries in a very short time).
Inverter: Fully automatic Phoenix 1600 Watt integrated with charger.
Supplies 240 volts to all 23 power points whether using shore power or not.
Insulation: Fully (and carefully) insulated with 25mm poly foam.
44,072 PostsLatest Activity: Aug 23, 2026
