brulaz
May 27, 2013Explorer
carmelo wrote:
Bottom line, it came down to Airstream and Evergreen Ever Lite line. The latter has NO wood in the construction only in the furniture. A composite floor, I cannot stress how important that is. Go on the Airstream Forum and see the number of rotted floors. Be aware that Ever Lites cost more than the run of the mill white box, about %25 or so.
They are all composite, even the floor is sandwich of aluminum and foam, as I said NO wood.
I think this has changed in 2013. According to the Evergreen Ever-lite brochure, there is now a plywood roof under the TPO. And the compositek backing in the walls is now optional. The compositek laminated floor seems to be the same though, and there's still an interior lining of compositek throughout.
If you want an Ever-Lite with a non-wood shell, you'll have to get a 2012 model or earlier. And make sure it is a true Ever-Lite, not an "Ever-Lite Select" which have the same model #'s but preceeded by an "S". The Select used wood in the shell.
44,072 PostsLatest Activity: Aug 23, 2026
