Terryallan
Jan 05, 2016Explorer II
aguablanco wrote:cbshoestring wrote:GordonThree wrote:
I thought my 20ft is pushing the payload on my 1/2 ton, can't imagine hanging a 28-30 ft on the bumper.
Good luck on your search, maybe one of those high tech aluminum frame models?
1st....on the bumper ??????
Anyone towing with a bumper mounted ball should be hog tied and beat with a wet noodle. I wouldn't pull a utility trailer on my bumber.
2nd....20ft is pushing the payload.
That must be one stout 20' trailer. My 19' has a dry weight of 2,600 with 900 payload for a total of 3,500. No where, not even close, to the 1668lb payload of my 1/2 ton RAM 1500.
3rd.... the length of a trailer has nothing to do with the payload placed on a truck. Sure, one can assume that a longer trailer will also be heavier, but last time I checked... adding LxWxH had nothing to do with weight.
I think you may be misconstruing how the term "bumper pull" is being used. It simply denotes a hitch and ball system, as opposed to a 5er. I couldn't imagine using the hole in the bumper for anything either.
RichH
Actually. the step bumper on "most" full size trucks, or SUVs is rated for no less than 5000lb, and 500lb tongue weight. And before the advent of receiver hitches, It was widely used to tow boats, popup campers, utility trailers ect, ect... Well anything less than the rated cap of the bumper.
Receiver hitches are a relativity new technology. Before they were introduced. If you were to need a heavier hitch. You had to order one specifically made for your vehicle.
So you should not be surprised to see boat trailers, and such sitting on Step, Bumper mounts. That is why the holes are there.
44,056 PostsLatest Activity: May 04, 2014
