OK...so I can say, NOT the Dometic Brisk 2 Air unit (non-ducted). Although it has cold air outlets pointing in all directions, cold air only comes out toward the back and sides. If your bed is forward of the AC unit, you will sweat (a lot) as there is little-to-no airflow in that direction. You must close off all the other outlets to get even just a little air moving toward the front. I took the cover down for inspection thinking maybe there was a blockage or perhaps an installation error, but nope, just bad airflow design.
