Durb
Mar 03, 2017Explorer
Txsurfer wrote:
Does the Edge read the trany data off the port or do you have to add sensors? I see you can add the EGT sensor - how hard is that and what does it really tell you?
The transmission temperature is off the port. The EGT sensor was an easy install on a 5.9 as I had good access to the exhaust manifold. There are precautions that must be made when drilling and tapping to pick up all the metal chips and prevent them from making it into your turbo. Earlier trucks such as mine would deliver power and generate heat to the point of doing damage to the engine. The monitor will help you alter your driving habits to keep that from happening.
44,027 PostsLatest Activity: Apr 19, 2019
