roundman
Apr 29, 2017Explorer
An 18" might be a great choice. I have been watching CraigsList for Dodge Ram 17" which was the OEM Standard rim...I will check into 18" also, I am not sure when or if Dodge began using 18" rims, anyone know?
One problem I have run into is trying to determine if rims that came on Rams after 2012 will fit onto a 2007. The bolt pattern and Hub Bore are apparently the same but the lug bolts went from 9/16" (like the 2007) to M14...so I am unsure if the lug bolt holes in the wheels are large enough to fit onto a 9/16" lug bolt.... Anyone know for sure? Thanks!
44,070 PostsLatest Activity: Aug 05, 2026
