canoe_on_top
Sep 24, 2021Explorer
I have been comfortable in my Artic Fox at a bit below zero. I have factory storm windows which, apparently, they no longer make. Thermopane would be the next, best thing. If you are looking at four season, remember that the dump valves have to be enclosed and heated, not just the tanks.Tank heaters are, also good.Winter camping pretty much requires 120 power. Ideally, shore power, otherwise, you will be running your generator quite a bit to keep the batteries charged because of furnace use. Would require a pretty good battery bank and a lot of solar to go that route.
44,071 PostsLatest Activity: Sep 17, 2026
