marcsbigfoot20b
Nov 18, 2021Explorer
I have a 2000 Bigfoot 27 foot. Bigfoot costs more but you get what you pay for if you need it for cold...or hot.
The things that make them work well are, Thermopane dual pane windows, big BTU heaters, very good insulation on all 6 sides, no slides, heated and enclosed tanks and valves, water tank in living space (like under bed) and water lines run through floor heater ducts, etc. They dont usually leak air as in if you have everything closed and turn on a fantastic fan you can hear the difference when you crack a window open.
Propane tanks are also enclosed.
As long as you have enough propane and solar to keep up with the heater blower motor, you are good to go.
On a side note, same with Phoenix 116 degree heat. Only difference is that it takes waaay more propane to run my built in generator for the air conditioning, but it will stay low 70s inside even in the sun.
