Gulfcoast wrote:
A question... On the travel trailer JT Strong Arm kits, why do they include just six arms and not eight? I want two stabilizer bars for each jack.
what you want to do is to stabilize side to side movement and up and down movement. All that takes for up and down is a jack at each corner for vertical load, and 3 points to stabilize lateral movement front to back and side to side. Adding a 4th for lateral stability actually can detract from stabilizing lateral movement since one of the 4 may likely be out of plane.
That's why only 3 points.
