spoon059 wrote:
I guarantee you that your wheels are rocking back and forth at least slightly as they move. That is a large portion of the movement that you feel. X-chocks or ONEstep or similar products that put opposing pressure on tires to limit rolling will help reduce movement.
All trailers have flex in the frame, lightweight trailers have more flex. Pooducts like the Strongarms appear to work great in terms of stiffening up a frame.
Agree ... there's no one solution that's going to eliminate all movement, in fact the only way to completely eliminate movement is to lift the trailer entirely off it's suspension, which is obviously not practical for any non-seasonal trailer. Rotational movement of the wheels
can be noticeably reduced with a set of BAL X-Chocks but they're not going to eliminate up / down suspension movement nor that caused by frame flex. With several of the trailers we've owned I've found the combination of a set of X-Chocks to reduce rotational movement and a set of BAL Single Tire Locking Chocks to absolutely prevent the trailer from inadvertently shifting regardless of site slope also works quite well in minimizing suspension movement and I've not had to go any further, such as also using JT Strongarms. However, every trailer is different, some exhibit considerable movement, others not so much, as is one's perception of how much movement is too much and how much is acceptable.
