jukes's avatar
jukes
Best Jacks to Stabilize TT
When trying to sleep if one of the kids moves the TT moves and I feel like I am on a boat!
We have Jacks (old ones) and new tire chocks.
Any recommendations on the best Jacks for better stabilization? anything else? It makes me feel a little sea sick....
We have a 30ft Jayco 2008 Featherlight TT.
Thank you!
  • No matter what you do, your travel trailer will always have wiggle and shake in it. Thousands of posts and thousands of responses on these forums for this very same issue. The only real solution, that actually works, (and I've been inside campers that had these installed), are adding JT Strong Arm Jack Stabilizers to your existing jacks. These do work, but to be most effective, get 4 sets, one for each jack on your camper. Click here for more info.
    The only other solution to completely eliminate trailer shake is to remove the wheels and set the entire camper on solid blocks.
    Thank you!
    Featherlite.. and 30', means that a lot of the movement is from frame flex. To fix this means a lot of support points. I am not gonna make any recommendations on just how to fix it (plenty will be along shortly) but multiple support points is the key. At least 3 per side.
