ttavasc
Jan 25, 2017Explorer II
ggolds5 wrote:SoundGuy wrote:Dick_B wrote:
Jayco has been around forever so they must be doing something right.
'Though now no longer a family business as it was during all those "forever" years, having been ***Link Removed*** to mega giant Thor Industries. Too early to say if that's good or bad but Jayco founder Lloyd Bontrager would probably be rolling in his grave if he knew the family had finally sold out his beloved creation. :(
It seems that the consences is that the Jayco JLX ultralights are "thrown together". Is this what most people think of these. Now I'm thinking steer clear of the cheaper anything ?.
We picked up a 2015 Jayco SLX 195RB and have put about 10,000 miles on it over the last two seasons. We have not had any significant issues during that time. Our situation sounds very similar - just the wife and I - so this floor plan works well for us.
A couple of things to point out. I saw a mention early on regarding the small holding tank sizes. For the 2017 model year both the black and grey tanks have been increased to 20g each. Prior to that they were 9g and 15g. Even so, the way that we use the trailer the small tank sizes don't pose any issues.
Regarding the cargo capacity - look at the Baja edition. The GVWR is increased to 3750 for that model. The Jayco web site doesn't list that on the summary specifications. As delivered ours was 3015lbs dry with a cargo capacity of 735lbs. We found that to be plenty for how we use the trailer. A couple of other nice features of the Baja edition are the factory flip axle which gives you several inches more ground clearance and upgraded LT load range C tires (LT235/75R15).
In general, the SLX line is an "entry-level" line with fewer standard options. As with all campers, there will be regular and routine maintenance that you will want to keep up with and various little modifications to make along the way. However, we found for the $$ this was a pretty good value.
