Blanco1
May 19, 2015Explorer
Best Mud Flaps?
I've notices with my snow & wet weather camping trips, I'm damaging my wood under the camper. & realize I need Mud Flaps. What might you recommend? Its a Dodge with a diesel & seems from my l...
deltabravo wrote:Blanco1 wrote:
I'm gonna call some of them links tomorrow & finally order some & maybe have my mechanic fit them for me if its not a simple bolt on?
Everyone's definition of how easy they are to install differs.
They aren't a simple bolt one - holes need drilled in the flaps, and usually need drilled in the lip inside the wheel opening.
Here's what I recall about mounting flaps after I remounted (relocated) a set of flaps on one of my trucks today.
Once you have the vertical and horizontal position determined, and are ready to start drilling, drill the top hole first. Secure the top with the mounting hardware, then make final adjustments for "level". The top screw becomes a pivot point. Once i had the top screw installed, I used a large grip clamp to hold the flap in position while I made final adjustments.
