Corky2
Aug 10, 2021Explorer
Kampfirekid wrote:goducks10 wrote:Corky2 wrote:
How does Grand Design compare to Thor on quality and owner satisfaction?
You gotta remember THOR owns a lot of RV companies. The more owned the more chances for problems.
Go over to the GD Owners Forum and read it for a month. You might be surprised.
***Link Removed***
I’m not sure GD is any worse/better than others. It does seem generally resolution to issues with a GD unit are a bit more likely. Maybe that’s what I’m reading. Frankly, unless you go with a full fiberglass Oliver, you’re just gambling if you got a good one or a bad one.
If I got a GD it would probably be the Imagine XLS series that is aluminum frame and fiberglass sides. They also have the sealed and heated underbelly.
44,072 PostsLatest Activity: Aug 30, 2026
