valhalla360
Jul 26, 2022Navigator
Basically, if you want to observe a video feed remotely, there needs to be a way to get that video feed from the trailer to where you are.
- Cheapest is a land line based internet but obviously, needs a really long cord, so that's not too practical with an RV.
- Cell hot spot is a bit more but you need a cell plan that has enough data and need to be in a coverage area.
- Certainly, you can do satellite but it's pretty much the most expensive option and you need a clear view of the sky in the vicinity of the satellites...plus the hassles of setting up each time you move.
- An off line camera seems to defeat the purpose as you must find the RV to collect the camera.
Unless you have some special use case, probably best to simply keep the insurance up and if it gets stolen, use the insurance check to buy a replacement...but really it's not that common for people to steal them unless you are hanging out in bad areas and since you have wheels, there rarely is a reason to hang out in bad areas.
44,071 PostsLatest Activity: Aug 23, 2026
