rjstractor
Nov 23, 2016Nomad
carringb wrote:
All of the Forest River Ford E450 motorhomes have a 7500# hitch receiver.
All THOR Ford E450 motorhomes have a 8,000# hitch receiver.
GCWR of the E450 is 22,000 pounds. GVWR is 14,500 so 7,500 is actually realistic, as long as the rear axle isn't over loaded with tongue weight and cargo.
x2, a shorter E450 based motorhome would make a pretty robust tow vehicle. If you could find one based on the GM Express 4500 that's an option as well, although IIRC they have a lower GCWR. The Sprinter and Transit Cs don't have the payload or GCWR that you'd need. The small As like the Vegas and Axis have 8K hitches, but are built on an E350 stripped chassis and as such only have a 12,500 GVWR and 18,500 GCWR. In the specs they don't list CCC or empty weight so that might be enough. Drivetrain is not a problem but payload could be.
