rjstractor
Nov 24, 2016Nomad
fugawi wrote:
Would you need weight distribution and/or sway control if you are pulling with a heavier vehicle like the small A's or Bedlam's rig?
I would consider it depending on your motorhome's axle weights with a full load and trailer connected. I set up an F550 at work towing a 7k enclosed trailer with about 900 pounds tongue weight and elected to use a weight distribution hitch because the truck was loaded close to its rear axle capacity and was fairly light on the front.
44,068 PostsLatest Activity: Jun 21, 2026
