downtheroad wrote:
Man o man, there are tons of lubricants out there for different applications...and just as many opinions about what is best and where.
I have Teflon spray, Silicone Dry Lube, Tri-Flo, WD-40 and a bunch of others I can't remember. Usually I just grab whatever.
To lube the hitch ball, I use hitch ball lube.....:S
Available lots of places. I got this at Walmart.
X2. Hitch ball lub as stated has the advantage of being available in a small container.
WD40 is not a lubricant.
I have some liquid wrench spray lubricant for most items that need a lub.
Some awnings use sylicon that is available in a spray too.
Those three will cover most needs.
