HUNTERJEFF's avatar
HUNTERJEFF
Explorer II
May 09, 2019
Best thing to use under jacks while unloading on grass
I was wondering what the best thing to put under the jacks while storing my camper on grass.
Thanks
Jeff
  • When & where? I have no problems unloading my camper on grass on level ground in the middle of summer. Ask me the same question in the middle of winter when the ground is soft an mushy, and you will get a different answer.
    Take 'grass' out of the question and insert sand, dirt, gravel, etc. The same thing applies. How stable is the surface? Is it likely to significantly compact over time? If so, then disperse the load by adding blocks under the jacks.
    And since you are 'storing'.... Yeah, put some sort of platform underneath to hold the load. Also probably put down some tarps to block stuff from growing up under the camper - you don't want to come back to your camper in a weed patch in a month.
    HTH,
    -Eric
  • In addition to the boards supporting the jacks, you might want to add a stack of pallets or other supports for the body of the camper so that the jacks do not have to carry the full weight. I do that even when storing on a hard surface.
  • I use pressure treated boards cut to 12" lengths. Lower the camper as close to the ground as possible too.
